Results 1 to 5 of 5
    February 2014
    0
    Q: ACRE- Transmit Squawk on issues
    Looking for some help or point me to some threads on an issue I'm having with ACRE, Teamspeak and Arma 2. When I'm in a game and I press the Caps Lock button to transmit, the transmit squawk on works fine the first time but the second and third times the transmit squawk on tone starts to have a delay then stops working altogether.
    Example:
    1st transmit- Caps lock pressed-instant transmit squawk on tone
    2nd transmit- Caps Lock pressed-3 second delay of transmit squawk on tone
    3rd transmit- Caps Lock pressed-10 second delay or just doesn't work at all
    Versions
    TeamSpeak- 3.0.13.1 (10/23/2013 5:10:11am) Qt version- 4.8.3
    ACRE- 1.4.10.500
    Jarma2Lib- 1.4.0.101
    Thanks, 0utLAW
    February 2014
    0
    So two nights ago I uninstalled TeamSpeak and installed TS 3.0.9 but the servers I connect to would not let me connect to them unless I updated to 3.0.13.1 which is what I was on before. I also reinstalled ACRE. Everything worked fine the first night. Then the next night after a reboot the same issues as above. Any help would be grately appreciated.
    February 2014
    0
    Bump - I am having the exact same issue. It makes using ACRE impossible, and the game unplayable.
    February 2014
    0
    aww. I got all excited that someone posted a response. sad that it's just another person having the same issue. Hey bud if you com accross any fixes, PLEASE let me know.
    18,261
    Guys you should contact the author of ACRE
    This forum has nothing to do with their product.
  1. Replies: 1
    Last Post: April 21st, 2013, 07:15 PM
  2. [No Bug] Ts3 + arma2 + acre
    By Forna in forum Bug Reports [EN/DE]
    Last Post: November 22nd, 2012, 11:20 AM
  3. Acre plugin
    By ferge100 in forum Client Plugins / Lua Scripts
    Last Post: April 24th, 2012, 06:35 AM
  4. Problem with Plugin (ACRE)
    By Chucki in forum Client Plugins / Lua Scripts
    Last Post: August 27th, 2011, 08:14 PM
