Results 1 to 2 of 2
    August 2011
    11
    How to limit where guests can create their temp. sub channels?
    Hi
    I cant figure out, how to limit in which permanent rooms can guests create their own temporary room.
    I limited min.depth so they need to make it inside one of permanent rooms I created, but I still want to limited them to just one.
    Example:
    --Admins
    --Clans
    --Temp Rooms
    and I want that guests can make their temp. rooms only in "Temp Rooms". It is possible?
    Now they can create it even in Admins room. Even I set there modify powers to 100 ..etc
    Thanks.
    edit:
    guest perms:
    Server Groups
    	Guest
    		b_virtualserver_token_use 1 0 0
    		i_channel_min_depth 1 0 0
    		i_channel_max_depth 10 0 0
    		b_channel_info_view 1 0 0
    		b_channel_create_child 1 0 0
    		b_channel_create_temporary 1 0 0
    		b_channel_create_with_topic 1 0 0
    		b_channel_create_with_description 1 0 0
    		b_channel_create_with_password 1 0 0
    		b_channel_create_modify_with_codec_speex8 1 0 0
    		b_channel_create_modify_with_codec_speex16 1 0 0
    		b_channel_create_modify_with_codec_speex32 1 0 0
    		b_channel_create_modify_with_codec_opusvoice 1 0 0
    		b_channel_create_modify_with_codec_opusmusic 1 0 0
    		i_channel_create_modify_with_codec_maxquality 7 0 0
    		i_channel_create_modify_with_codec_latency_factor_min 1 0 0
    		b_channel_create_with_maxfamilyclients 0 0 0
    		b_channel_create_with_needed_talk_power 0 0 0
    		i_channel_delete_power 60 0 0
    		b_channel_join_permanent 1 0 0
    		b_channel_join_semi_permanent 1 0 0
    		b_channel_join_temporary 1 0 0
    		i_group_auto_update_type 15 0 0
    		i_group_needed_modify_power 75 0 0
    		i_client_max_clones_uid 0 0 0
    		i_client_max_avatar_filesize 99999 0 0
    		i_client_max_channel_subscriptions -1 0 0
    		b_client_request_talker 1 0 0
    		b_client_info_view 1 0 0
    		i_client_needed_serverquery_view_power 75 0 0
    		i_client_needed_kick_from_server_power 25 0 0
    		i_client_needed_kick_from_channel_power 25 0 0
    		i_client_needed_ban_power 25 0 0
    		i_client_needed_move_power 25 0 0
    		b_client_channel_textmessage_send 1 0 0
    	All
    Client
    Channel
    	Public 1  [GP]
    		i_channel_needed_modify_power 50
    		i_channel_needed_delete_power 50
    		i_icon_id -242037096
    Channel Groups
    	Guest
    		b_channel_create_private 0
    		b_channel_create_modify_with_codec_celtmono48 1
    		i_channel_create_modify_with_codec_maxquality 75
    		i_channel_create_modify_with_codec_latency_factor_min 75
    		i_channel_subscribe_power 25
    		i_group_auto_update_type 10
    		i_client_max_avatar_filesize 200000
    		i_client_private_textmessage_power 25
    		b_client_offline_textmessage_send 1
    Channel Client
    All
    	b_channel_create_private 0 0 0
    	b_channel_create_modify_with_codec_celtmono48 1 0 0
    	i_channel_create_modify_with_codec_maxquality 75 0 0
    	i_channel_create_modify_with_codec_latency_factor_min 75 0 0
    	i_channel_needed_modify_power 50 0 0
    	i_channel_needed_delete_power 50 0 0
    	i_channel_subscribe_power 25 0 0
    	i_icon_id -242037096 0 0
    	i_group_auto_update_type 10 0 0
    	i_client_max_avatar_filesize 200000 0 0
    	i_client_private_textmessage_power 25 0 0
    	b_client_offline_textmessage_send 1 0 0
    Channel Admin:
    Server Groups
    	Guest
    	All
    Client
    Channel
    		i_channel_needed_permission_modify_power 0
    		i_channel_needed_delete_power 60
    Channel Groups
    	Channel Admin
    		b_channel_create_with_maxclients 0
    		b_channel_modify_parent 0
    		b_channel_modify_make_temporary 1
    		b_channel_modify_name 1
    		b_channel_modify_topic 1
    		b_channel_modify_description 1
    		b_channel_modify_password 1
    		b_channel_modify_codec 1
    		b_channel_modify_codec_quality 1
    		b_channel_modify_codec_latency_factor 1
    		b_channel_modify_maxclients 1
    		b_channel_modify_sortorder 0
    		b_channel_modify_needed_talk_power 1
    		b_channel_modify_make_codec_encrypted 1
    		b_channel_delete_permanent 1
    		b_channel_delete_semi_permanent 1
    		i_channel_description_view_power 50
    		i_icon_id 100
    		b_group_is_permanent 1
    		i_group_auto_update_type 40
    		i_group_member_add_power 50
    		i_group_needed_member_add_power 50
    		i_group_member_remove_power 50
    		i_group_needed_member_remove_power 50
    		i_permission_modify_power 0
    		b_client_is_priority_speaker    10
    		b_client_use_channel_commander 1
    		i_client_kick_from_server_power 0
    		i_client_kick_from_channel_power 25
    		i_client_needed_kick_from_channel_power 50
    		i_client_ban_power 0
    		i_client_move_power 25
    		i_client_needed_complain_power 25
    		i_client_talk_power 60
    		b_client_set_flag_talker 1
    Channel Client
    All
    	i_channel_needed_permission_modify_power 0 0 0
    	b_channel_create_with_maxclients 0 0 0
    	b_channel_modify_parent 0 0 0
    	b_channel_modify_make_temporary 1 0 0
    	b_channel_modify_name 1 0 0
    	b_channel_modify_topic 1 0 0
    	b_channel_modify_description 1 0 0
    	b_channel_modify_password 1 0 0
    	b_channel_modify_codec 1 0 0
    	b_channel_modify_codec_quality 1 0 0
    	b_channel_modify_codec_latency_factor 1 0 0
    	b_channel_modify_maxclients 1 0 0
    	b_channel_modify_sortorder 0 0 0
    	b_channel_modify_needed_talk_power 1 0 0
    	b_channel_modify_make_codec_encrypted 1 0 0
    	b_channel_delete_permanent 1 0 0
    	b_channel_delete_semi_permanent 1 0 0
    	i_channel_needed_delete_power 60 0 0
    	i_channel_description_view_power 50 0 0
    	i_icon_id 100 0 0
    	b_group_is_permanent 1 0 0
    	i_group_auto_update_type 40 0 0
    	i_group_member_add_power 50 0 0
    	i_group_needed_member_add_power 50 0 0
    	i_group_member_remove_power 50 0 0
    	i_group_needed_member_remove_power 50 0 0
    	i_permission_modify_power 0 0 0
    	b_client_use_channel_commander 1 0 0
    	i_client_kick_from_server_power 0 0 0
    	i_client_kick_from_channel_power 25 0 0
    	i_client_needed_kick_from_channel_power 50 0 0
    	i_client_ban_power 0 0 0
    	i_client_move_power 25 0 0
    	i_client_needed_complain_power 25 0 0
    	i_client_talk_power 60 0 0
    	b_client_set_flag_talker 1 0 0
    Secret Base in Arctic Region
    1,671
    Remove "b_channel_create_child" permission from guest-servergroup.
    Set it on the channel you want them to create subchannels, i. e. your "Temp Rooms" channel.
  1. Allowing users to only create temp. channels under a spacer?
    By Matt8991 in forum Permission System
    Last Post: June 15th, 2014, 08:14 PM
  2. guests can create channels
    By jneves in forum Permission System
    Last Post: February 14th, 2012, 01:51 PM
  3. [On Todo] Force subchannel option/ limit guests from creating channels under last channelintree
    By kozarman1 in forum Suggestions and Feedback
    Last Post: February 4th, 2011, 01:13 PM
  4. [solved] Safe way to allow guest create temp channels ?
    By Wolfseye in forum Permission System
    Last Post: August 24th, 2010, 08:33 PM
  5. [SUGGESTION] Create sub-channels w/ temp, semi and/or permanent
    By poisonpanik in forum Suggestions and Feedback
    Last Post: July 21st, 2010, 03:38 PM
