Results 1 to 2 of 2
    May 2007
    Eastern NC
    1,794
    Error in message box when attempting to delete in use identity
    While connected to a server and attempting to delete the in use identity results in a message box that states "You cannot remove an identity which is connected to a server." but instead of an OK button it has Yes and No buttons. Both close the window, but since I'm not being ask if I want to disconnect and delete or not there is no reason for Yes/No buttons.
    Also, would suggest not using the question icon in the messagebox since it is not a question.
    Or add a second line "Do you want to close all server connections using this identity and delete it?" and the needed code to support that. Then the question and Yes/No buttons would make sense.
    17,936
    I agree and suggest to use "OK" here with an hint to disconnect from the server.
    Last edited by dante696; March 17th, 2014 at 03:10 PM. Reason: moved from bug section
  1. [No Bug] Bug: Able to delete default identity when should be impossible.
    By Morthawt in forum Bug Reports [EN/DE]
    Last Post: July 8th, 2014, 07:09 AM
  2. Error Report When Attempting to Start TS 3 Application
    By Csm308 in forum Bug Reports [EN/DE]
    Last Post: August 7th, 2011, 10:04 PM
  3. [Resolved] Public test server returning "convert error" when attempting to connect
    By Screech in forum Bug Reports [EN/DE]
    Last Post: May 7th, 2011, 12:42 PM
  4. When attempting to ServerQuery :- Error
    By Krispy101 in forum Windows
    Last Post: January 7th, 2010, 06:50 PM
