Results 1 to 13 of 13
    November 2012
    Higher resolution icons for 4K or retina displays
    Currently TeamSpeak 3 is not retina resolution ready. Everything looks pixelated, so I was hoping this could be addressed and fixed. The Retina MacBook Pro 15" screen is 2880x1800 resolution, and the Retina Macbook Pro 13" is 2560x1600 resolution.
    Thanks for reading.
    October 2003
    2,527
    Please try this:
    1. Open the application package (Right-click > Show Package Contents)
    2. Edit the file Info.plist using XCode
    3. Add a new key-value pair NSPrincipalClass/NSApplication (see screenshot below)
    4. Restart your MacBook or re-login
    http://250kb.de/u/121112/p/UFABjG9lB9Iy.png
    Please let us know if this works for you and maybe attach a screenshot of how your client looks.
    November 2012
    It didn't work. Even if it did, I don't see how it could fix things like the blue circle in the menu bar or any of the buttons/pictures.
Name:	Screen Shot 2012-11-12 at 1.47.45 AM.png
Name:	Screen Shot 2012-11-12 at 1.47.41 AM.jpg
    November 2012
    Anybody want to look into this? I'm not asking much, just compatibility for a simple technology update.
    18,513
    Quote Originally Posted by DannySwish View Post
    We a aware about the problems with retina displays and a ticket for this already exists in our system. It's more than just a simple technology update
    December 2012
    http://retinizer.mikelpr.com/ is a nice tool that will make all the text crisp. I think it does the same thing ScP recommends but without having to deal with xcode and everything. Works for me, but ymmv.
    November 2012
    Solved my problem. Thanks!
    March 2014
    Post Higher resolution icons for 4K or retina displays
    It would be really good to update TeamSpeak so it has higher resolution icons for retina displays. This has been done this for the iPhone App, and if the desktop program had retina icons, it would be an improvement and look great.
    August 2013
    Angry Retina still not supported after having an evaluation of 2 years
    First post about this issue is linked here and almost 2 years have passed and still no support has been added. Qt supports retina for exactly 1 year and four days since the day that this was posted. Not being a Qt developer myself, I looked around how hard it is to add support for this in Qt and it seems to be very simple. It is better to add support for Mac because Windows will have to get some decent high-res support soon.
    October 2003
    2,527
    I fully agree... However, the Retinizer app works so you can make the client look a bit nicer:
    August 2013
    I have used the Retinizer app, but it's incompatible with other software I use on a daily basis (like Adobe software) which makes it very annoying to use the app only for Teamspeak since it's the only program that didn't add support for over 2 years.
    June 2015
    TeamSpeak is the only app I use which has not updated its graphics and text. Please fix it already, its overdue in 2015.
    January 2009
    31
    TeamSpeak is the only app I use which has not updated its graphics and text. Please fix it already, its overdue in 2017.
  1. Replies: 0
    Last Post: November 20th, 2014, 12:37 AM
  2. TS3 and the two displays.
    By KrabKley in forum Bug Reports [EN/DE]
    Last Post: April 20th, 2011, 03:15 PM
  3. Displays
    By xcalibur in forum General Questions
    Last Post: January 9th, 2010, 09:17 AM
