Page 1 of 3 123 LastLast
Results 1 to 15 of 43
    March 2014
    Client 3.0.14 (and nerwer) error message (0xc000001d)
    Please read this post first before reporting
    Click me
    Hi, I am frequent TS user . I updated ts lately to 3.0.14 . and after the update its not working . I tried re-installing ts to previous version but I found out I can't proceed without updating.
    thanx.
    March 2014
    I have the same issue and I'm getting the same message application failed (0xc000001d) , this happened right after I updated the Ts3 Client. I updated everything , re-installed the teamspeak cliet a dozen times , check on you tube for any answers , did system restore, ran multiple scans and nothing seems to fix this error!!!! And I can only imagine it is something very simple to fix , and btw I am running windows Xp and had been running teamspeak on Windows Xp for several years with no problems until Today. :-(
    March 2014
    Hi , I am still stuck with this problem, is it possible to get some help plz?
    P.S.: plz check my previous post for Screenshot , in this very thread.
    18,151
    Quote Originally Posted by keyos View Post
    This i an windows error code, and that is nothing we can fix.
    Try to deactivate your firewall or antivirus tools (in worst case try to deinstall them for testing)
    Check that non of your RAM is broken.
    6,078
    According to several Google results this seems to be a Windows XP related error caused by corrupted system files. But since Windows XP is officially dead in a few weeks and vulnerable to all sorts of attacks and bugs, you shouldn't worry about it and instead update to at least Windows 7 while you still can.
    March 2014
    Question Ts3client_win32.exe - Application Error
    When I try to open TS3 I get this error "The application failed to initialize properly (0xc000001d)". Could someone help me to solve this problem? I have windows XP sp2 and I reinstall NET 3.5 SP1, but that did not solve the issue. Thank you in advance.
    March 2014
    Quote Originally Posted by RikyRO View Post
    i have the same.
    before i updating teamspeak, it works fine.
    i love to game, and i love teamspeak too.
    so, i get the same errorcode, after update.
    i have try all things, that i see here, that helps the others.
    i deinstall/delete all plugins in the teamspeak directory.
    i have try to run the update.exe in teamspeak directory, same errorcode. 0xc000001d
    everytime, i try to run some of the teamspeak *.exe i get this errorcode.
    i delete and reinstall ALL Frameworks.
    (1.1 -4.0)
    i checked windowsupdates.
    i check my hardware, all works fine.
    i realy need help.
    i have no idea, what i make wrong with this.
    i dont get any crashdump file, nothing - only this errorcode.
    google cant help.
    all the posts here cant help.
    i hope, someone of this peoples can help me here.
    March 2014
    Question Error (0xc000001d), any help?
    ts3client_win32.exe
    I get this error when I freshly installed TS3:
    Failed to initialize (0xc000001). Click OK to terminate application.
    I'm running Windows XP SP3 (Not my main rig, but a secondary driver)
    And I already tried updating the .NET Framework (3.5 SP1) and the Visual C++ Redistributable (2008 SP1).
    Another strange thing is that this message appears again when I click OK on the first one, however it doesn't repeat after that.
    18,151
    We still can not reproduce that here.
    Has anyone tried to deactivate the current antivirus/firewall protection?
    What happens, when you start the updater a second time? (C:\Program files\TeamSpeak 3 Client\update.exe)
    edit
    What CPU does anyone have?
    October 2003
    2,526
    People who get the 0xc000001d error peobably have older CPUs. This error means "Failed to initialize" and usually appears when one or more files are corrupted... or in this case, when the processor is missing the SSE2 instruction set.
    http://en.wikipedia.org/wiki/SSE2#CPUs_supporting_SSE2
    April 2014
    ts3client_win32.exe
    Someone help to fix it! :/
    18,151
    Please scroll up to post #9 and #10 straight above your report.
    It won't help you, but it helps us to analyze the problem.
    April 2014
    problem with teamspeak3
    Hello then i try to run teamspeak i got application error : http://www.part.lt/perziura/3d5f0c05...8e61cea403.JPG
    please help me
    April 2014
    May 2007
    Eastern NC
    1,798
    At this point I think any support for Windows XP would be to simple update to a newer version of Windows message. The OS maker has stated it is end of life, no reason for 3rd parties to support it at this time. As an end of life product I see it as being equal to running Windows 3.1 on DOS 6.2, simply no longer supported.
  1. Error Message on Client Click
    By Z3ROH3ALTH in forum Windows
    Last Post: May 15th, 2011, 02:26 PM
  2. Error message: invalid client type
    By Conreason in forum Suggestions and Feedback
    Last Post: March 25th, 2010, 08:05 AM
