Results 16 to 30 of 43
  1. #16
    October 2003
    2,510
    Quote Originally Posted by manyy View Post
    I have the same issue and I'm getting the same message application failed (0xc000001d) , this happened right after I updated the Ts3 Client. I updated everything , re-installed the teamspeak cliet a dozen times , check on you tube for any answers , did system restore, ran multiple scans and nothing seems to fix this error!!!! And I can only imagine it is something very simple to fix , and btw I am running windows Xp and had been running teamspeak on Windows Xp for several years with no problems until Today.
    At this point I think any support for Windows XP would be to simple update to a newer version of Windows message. The OS maker has stated it is end of life, no reason for 3rd parties to support it at this time. As an end of life product I see it as being equal to running Windows 3.1 on DOS 6.2, simply no longer supported.
    As I described earlier, the error is caused because your CPU doesn't support the SSE2 instruction set that is somehow required by the new client release. This has nothing to do with Windows XP beeing too old (the CPU in fact is). I fully agree with Screech tho... people should use an OS that's still beeing maintained by M$.
    My guess is that the new SSE2 requirement snuck in there by mistake with the build system updates the devs described here... as the the System Requirements page has not been updated before/with the release (seems to be reviewed now) and it's not mentioned in the release thread, news or changelog.
    Anyways... I'd suggest that anyone getting this error should downgrade to 3.0.13.1 for now and wait for the next client pre-release that will hopefully fix this error for people with older CPUs.
  2. #17
    17,940
    The system requirements for client and server will get an overhaul and we are not sure yet if SSE2 stays in our client software.
    That would need one of these CPUs as a minimum:
    Intel Pentium4 or AMD Athlon 64 (or VIA C7)
  3. #18
    May 2007
    Eastern NC
    1,794
    Yeah, understand it is a processor feature missing issue. But so far almost every report (quickly scanning this thread) is from XP, maybe the reason they are still running XP is that the hardware didn't work well with Vista or 7. So if their hardware is not ideal for a newer OS hardware would likely get updated to a processor supporting SSE2 too.
  4. #19
    April 2014
    Unhappy Help me please !!!ERROR TEAMSPEAK3
    http://postimg.org/image/8ulvbdbin/a0fceb58/
    http://postimg.org/image/bgwbvdrc3/
    Teamspeak3 ERROR help me.
    And error or the update TEAMSPEAK3
    net framework :YES
    C++ :YES
    how the error ? (you rezolved?)
  5. #20
    2,698
    Quote Originally Posted by Bratuleanu Alex View Post
    Read the whole thread, specially posts 9, 10 and 16:
    http://forum.teamspeak.com/showthrea...c000001d)-quot
  6. #21
    April 2014
ID:	10424Click image for larger version.
    Why you release bad version ? Is very bad engineered full of bugs and laggy. 3.0.13 works on my pc. How can i run this software ?
    German engineering, how it works ? never even start up
  7. #22
    May 2014
    Unhappy Error
    I have a problem with Team Speak 3 client since reinstalled windows miam
    I get an error "The application failed to initialize Properly (0xc000001d) '.
    Please send your answer to help me and I do not understand why I no longer go
  8. #23
    June 2014
    application error unable to start correctly (0xc000001d)
    This is all i get when trying to start ts3 , i have a fresh windows 7 install and nothing else on the computer as yet.
  9. #24
    17,940
    You may read this.
    http://forum.teamspeak.com/showthrea...118#post376118
    What CPU do you use?
  10. #25
    June 2014
    it`s old - amd xp2600 2.08ghz but all i want the computer for is teamspeak
  11. #26
    17,940
    The current client (3.0.14 / 3.0.15 beta) must use a CPU with SSE2 support.
    Your Athlon XP has no such feature.
    Please use client 3.0.13.1 until we give any new feedback about a soloution or decision.
    http://dl.4players.de/ts/releases/3.0.13.1/
  12. #27
    April 2014
    Problem with the new version.
    When i updated my ts3, the program send me an error and i cant open it since then. Here is the error window:
    http://www.img-share.eu/f/images/10/untitledt8cZZ4G.bmp
  13. #28
    6,076
    TeamSpeak requires a CPU with SSE2 Support since version 3.0.14
  14. #29
    August 2014
    Novi Sad, Serbia
    Can't update to any client of 3.0.14,3.0.15.1 and 3.0.16
    Well, like I said, I have to use version 3.0.13 of TS3 client on Windows. Got some cracked Win XP SP3. I' ve installed MS .net framework 3.5 SP1, but same happens. When I install versions 3.0.14; 3.0.15 or 3.0.16, got the same. Error on startup.What I can do? And, How I can have the Non-Profit Licence for my TS3,if I do not have static IP? Regardly, Jovan.
    Last edited by dante696; August 11th, 2014 at 10:55 AM. Reason: merged - but miss details about the error
  15. #30
    August 2014
    Novi Sad, Serbia
    So, problem is with the procesor? I need stronger one?
  1. Error Message on Client Click
    By Z3ROH3ALTH in forum Windows
    Last Post: May 15th, 2011, 02:26 PM
  2. Error message: invalid client type
    By Conreason in forum Suggestions and Feedback
    Last Post: March 25th, 2010, 08:05 AM
