Page 4 of 6 FirstFirst ... 23456 LastLast
Results 46 to 60 of 85
  1. #46
    August 2013
    12
    ts3 private message client crash
    Without actually posting what they send people to you guys.. (basically a string of bad/broken images)
    if you get private messaged the string and try to open your TS client crashes.
    i dont want to turn off guests ability to private message people but is there a way to stop this outside of this?
    server is current version and my client is too
  2. #47
    May 2007
    Eastern NC
    1,801
    I have a LUA module to protect from the formats of this I know of on my server: http://screech.me/ts3/plugins/antifreeze.html
    This is a client side LUA module and since you can't make them install it, maybe until new client is release you could disable guest PM and channel text to protect everyone from random guest.
  3. #48
    October 2010
    67
    Lightbulb
    disable network access ...
    If your client crashes the whole time and you can't start teamspeak anymore you can delete the chatlog manually.
    Just take a look in the installation directory of teamspeak.
    Example:
    D:\20_Programme\TeamSpeak 3 Client\config\chats
    Delete the "chats" folder and everything works fine. If you don't want to delete all your chatlogs it's also possible to edit a singe chatlog. In the "chats" folder you have to search for the specified server by checking all the "server.html" in each subfolder. Then take a look in the subfolder "TeamSpeak 3 Client\chats\<SERVER_UNIQUE_ID>\clients".
    You have to edit the *.txt file and the *.html file of the client which sent you the message.
    Greetings.
  4. #49
    May 2014
    [BUG/GLITCH] HELP - All clients in one channel crashing after a few lines of code..
    hello all,
    first time posting so unsure if this is the correct area, apologies if it isnt.
    recently i have had an issue where a certain individual has pasted a few lines of code that include the tags [img] in the chat box of the channel that they are in causing anyone in that channel to have their teamspeak client freeze and then crash, it has been reported from my admins and community members that it only affects those that can see the message so basically anyone that is in the channel with the individual in question, i havent yet tested private messages but i will get on to that a report back if that is affected aswell. I have contacted my host but they said that it was bizarre situation that they havent encountered before and suggested to post here on the forums.
    i went into a channel by myself on a backup server in a new tab and pasted one line of the code and my client froze for about 1 minute so i would assume that if i post all of them then i will probably see the full effect, also in the chat box an image of a paper icon thing was there after the client unfroze
    i have not posted the code as if its a major problem that affects all servers then i dont think it would be wise to have it freely seen, but if it is required then i can post it.
    so i ask
    is this something that is known already?
    is there a fix for it and if so how would i go about implementing a fix?
    If there is no fix yet then would you recommend that i just make all new people to the server set as a rank that cannot chat until assigned another rank? although i wouldn't really like to do this unless i have to
    Also this individual has been banned by admins previously but he uses an ip changer and as a result ban evades, i assume he also is smart enough to make a new identity so that type of ban would also be ineffective, so is there a way i can get rid of this guy other then a server password as i would like to keep the server publicly available
    thank you in advance for reading.
  5. #50
    May 2014
    TS3 (not responding) or hanging when connecting to server
    When i try to connect to a server ts3 will hang on (not responding) for a minute and then finally say "connected". If i try to click on the chat tab for the room im in it freezes the program too. This has just started a few days ago and it used to work fine. nothing has changed that i know of.
  6. #51
    May 2014
    TS3 freezes on connect
    My teamspeak client suddenly started freezing when i try to connect to a server.
    I tried to uninstall and reinstall it but it still has the same problem.
    Additional Info: I use windows 8 but the client worked for months, i got the latest update a few days ago but it was fine until today.
    Help!
  7. #52
    May 2014
    Question Teamspeak 3 Server (Crashing Certain Clients On Connect)
    My community has recently come into a big problem. A good chunk of our clients just stopped responding. When we reconnect we can hear people talking etc but we don't have the teamspeak voice telling us we're connected or anything. This hasn't happened to all of our clients only a selected few. This is a big problem. Has any one encountered this? What can I do to prevent this?
  8. #53
    4,368
    Might be this.
  9. #54
    May 2014
    Might be this.
    Yes that's exactly the problem. They need to hurry up and release a fix because this is a complete joke! People pay for a license to run teamspeak and this exploit is crushing our communities.
  10. #55
    May 2007
    Alabama
    54
    when new version fix bad bug bbc.
  11. #56
    May 2014
    Teamspeak3 Not Responding when I connect to a specific Server
    Basically, when I connect to my Teamspeak3 Server Teamspeak becomes unresponsive for upwards of 1-3 minutes. After this time it will go away but if I click off the Teamspeak Client and then back on it to move channels I receive the 'not responding' error message again. This only started yesterday. Any suggestions?
  12. #57
    4,368
    Read this. It's a very serious exploit, however, TeamSpeak takes centuries to release a patch.
  13. #58
    May 2014
    so the problem is with teamspeak itself not my server/computer?
  14. #59
    4,368
    If it could be that someone sent you malicious bbcode, yes.
  15. #60
    May 2014
    How could I check and/or remove it?
  1. Original (Default) theme chat color code
    By Saurik in forum Skins / Icon & Sound Packs
    Last Post: August 9th, 2014, 04:59 PM
  2. [On Todo] TeamSpeak 3 BB Code Freeze Round II
    By Mumble_is_better in forum Bug Reports [EN/DE]
    Last Post: July 11th, 2014, 03:17 PM
  3. Improve chat - Increase max message length and allow [img] BB code
    By snostorm in forum Suggestions and Feedback
    Last Post: May 4th, 2013, 03:48 AM
  4. [Resolved] 3sec freeze when someone send a link to chat
    By Falenone in forum General Questions
    Last Post: June 26th, 2011, 03:50 AM
