Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    April 2014
    error_failed_connection_initialisation
    Hey, i bought for my device (Galaxy Note 2 ) from the Google play store the Ts3 app
    and it worked fine for 3 days. But now if i try to connect on a server
    i get everytime a ERROR_failed_connection_initialisation. I use only Wifi and my connection is Stable
    if would be nice if someone can help me.
    6,076
    Might be the server you're trying to connect to. Check if you can connect from a PC in the same network. If you cannot then something is wrong with either the server or the network configuration.
    April 2014
    Yes, i can connect from a PC in the same network
    what could be wrong with my configuration ?
    November 2011
    10
    I too am having this same problem. Just bought the app on google store and input the correct details for the server and this error pops up. I can connect to it using my PC. my phone is an android 4.1.2
    18,029
    noscapin & NoWay32
    Can you send me the server details in a private message? We'd like to retest your situation.
    18,029
    NoWay32
    I was able to connect to the server with pc and android device.
    November 2011
    10
    Show me what u put in each field.
    18,029
    I just have used your given details
    Label: test
    Address: ts3.*******.us
    Server Password: passwordhere
    Please ask someone for the server ip instead. This seems to be a normal DNS problem only.
    November 2011
    10
    its not working for me. I used the actual IP and I also used the port with the IP...nothing same error.
    2,698
    Quote Originally Posted by NoWay32 View Post
    Are you using wi-fi, I mean, the same network as the PC, or are you using your mobile connection?
    November 2011
    10
    Its a mobile network not WiFi.
    2,698
    Could you try connecting from your mobile device to the TS3 server but using a wi-fi network? Coudl be the same as your PC?
    I mean, if your device connects to the server from a wifi but not from your mobile connection, then your mobile connection is limiting the access to the server, not the Android app.
    November 2011
    10
    I've tried using Wifi too. nothing....
    2,698
    Do you have some firewall app in your device?
    November 2011
    10
    No sir. No app with any security functions in the phone.
  1. ERROR_failed_connection_initialisation
    By syler91 in forum Android
    Last Post: October 20th, 2015, 01:29 PM
  2. ERROR_failed_connection_initialisation
    By tiga05 in forum Android
    Last Post: September 24th, 2015, 06:59 PM
