Results 1 to 6 of 6
    January 2014
    86
    Invalid permission ID
    when I add permission: Group is Permament I had error: "Invalid Permission ID" its Guest.
    Help me
    Regards,
    DziuDziu
    18,259
    Your description is not enough to explain what is going on.
    Are you trying to set the default Guest group to permanent?
    The default server group can not be set to permanent. It must be a temporary group.
    6,080
    You cannot set the default group to permanent, attempting to do so will yield the error you describe.
    July 2014
    25
    Sorry to necro this thread, but my issue is on this topic and the answer doesn't fully quench my curiosity.
    When I try to "Add Permission" to the GUEST server group's "Group is Permanent" setting (it is currently greyed out), I get an error message "invalid permission ID."
    The above answer by Chris would make me think that this GUEST group setting cannot be altered.
    My issue is that I have an older server that has the GUEST server group's "Group is Permanent" permission ticked off and I am UNABLE TO REMOVE the permission on that server.
    Is it normal for the Guest "Group is Permanent" setting to be greyed out and unalterable by the server admin currently? Or is there a setting I am overlooking that I need to change that will allow me to change it? I just installed this server, so the setting was greyed out when I first saw it.
    My current server version is 3.9.1 on a Linux box. My older server version is 3.0.10.3 on a Windows Server (from January 6, 2014 according to the old releases page).
    18,259
    You can not make the group permanent or delete as long the group is set as the default server group on that server.
    These are the only restrictions for the group.
    July 2014
    25
    Thank you for clarifying that! I appreciate it!
  1. Replies: 1
    Last Post: September 17th, 2016, 01:54 PM
  2. Login denied (invalid permission 0x2226)
    By ritchy in forum Permission System
    Last Post: October 19th, 2011, 04:29 PM
