Results 1 to 2 of 2
    October 2013
    6
    Question [HELP] Error loading plugin (Error code 193)
    Hi there,
    Yesterday I started to take a look at TeamSpeak's Plugins SDK and saw there was a sample project which I tried to compile with v120 (I'm using Microsoft Visual Studio 2013) as I don't have any older version of VStudio.
    As soon as the TeamSpeak starts up and I try to load the plugin, I'm getting an error which code is 193 (appeared in the Client Log). I've searched over Internet about that error code and found the following details for this error: "not a valid Win32 application".
    I don't know what I'm doing wrong, I uploaded the full Visual Studio solution so you can see what's wrong there.
    I would be much appreciated if you could help me
    Thanks in advance,
    UngarMax.
    Attached Files Attached Files
    6,076
    Error 193 is when you attempt to load a 32 bit library into a 64 bit application or vice versa. Since the project only has a 32bit Configuration I assume you're using a 64bit client.
