Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
  1. #16
    May 2012
    The 3rd dimension
    956
    I checked mine on Ubuntu server and it already had the correct space. I am still unable to type. I doubt this is a linx problem since I had, at the time, one client working and the updated one not working. I could go back and forth and the new update and everyone since does not let me type.
  2. #17
    August 2014
    Fresh install of Ubuntu 14.04 with latest TeamSpeak client 3.0.16 (amd64) with a razer blackwidow keyboard.
    Keyboard randomly stops working only when TeamSpeak is running.
    Close TS, unplug USB and reconnect and the kb starts working again.
  3. #18
    April 2015
    Can't type on TeamSpeak client (Ubuntu 14.04 VNC)
    I am trying to run TS3 Client on my Ubuntu 14.04 server (VNC) so I can view everything there, whenever I install it I can copy and paste entries by using right click options, but I can not type using my keyboard. My keyboard is working with everything else on the VNC server.
    Any help is much appreciated.
    Thanks,
    Kevin.
  4. #19
    April 2014
    Xubuntu 14.04 64 bit
    Ts 64 bit problem contiounus...
    [[email protected]] ~/İndirilenler/TeamSpeak3-Client-linux_amd64
    ❯ ./ts3client_runscript.sh
    Error: Could not resolve keysym ISO_Level2_Latch; Symbol interpretation ignored
    Error: Could not resolve keysym ISO_Level3_Shift; Symbol interpretation ignored
    Error: Could not resolve keysym ISO_Level3_Latch; Symbol interpretation ignored
    Error: Could not resolve keysym ISO_Level3_Lock; Symbol interpretation ignored
    Error: Could not resolve keysym ISO_Group_Latch; Symbol interpretation ignored
    Error: Could not resolve keysym ISO_Next_Group; Symbol interpretation ignored
    Error: Could not resolve keysym ISO_Prev_Group; Symbol interpretation ignored
    Error: Could not resolve keysym ISO_First_Group; Symbol interpretation ignored
    Error: Abandoning compatibility map "default"
    Error: Abandoning compatibility map "complete"
    Error: Abandoning compatibility map "(unnamed)"
    Error: Failed to compile xkb_compatibility
    Error: Failed to compile keymap
    Qt: Failed to compile a keymap
    2015-05-27 18:56:39.235667|INFO | | | TeamSpeak 3 Client 3.0.16 (2014-08-04 13:42:43)
    2015-05-27 18:56:39.235788|INFO | | | SystemInformation: Linux 3.16.0-38-generic #52~14.04.1-Ubuntu SMP Fri May 8 09:43:57 UTC 2015 x86_64 Binary: 64bit
    2015-05-27 18:56:39.235842|INFO | | | Using hardware aes
    2015-05-27 18:56:39.248661|DEBUG |PulseAudio | | connected to pulse audio server
    2015-05-27 18:56:39.273858|INFO | | | Loading plugin: libappscanner_plugin
    2015-05-27 18:56:39.273927|INFO | | | Loading plugin: libclientquery_plugin
    2015-05-27 18:56:39.273968|INFO | | | Loading plugin: liblua_plugin
    2015-05-27 18:56:39.274005|INFO | | | Loading plugin: libtest_plugin
    2015-05-27 18:56:39.275714|INFO |Query | | listening on 127.0.0.1:25639
    ClientQueryPlugin: currentServerConnectionChanged 1 (0)
    2015-05-27 18:56:39.653531|INFO | | | *** Time [MAINWINDOW]: 197
    2015-05-27 18:56:39.653705|INFO | | | *** Time [INIT]: 197
    2015-05-27 18:56:39.657135|INFO |ClientUI | | Failed to init text to speech engine
    2015-05-27 18:56:39.657228|INFO |ClientUI | | Qt version: 5.2.1
    2015-05-27 18:56:39.657283|INFO |ClientUI | | Using configuration location: /home/plazma/.ts3client/settings.db
    2015-05-27 18:56:40.154790|INFO |ClientUI | | Last update check was: Çar May 27 18:48:29 2015
    QTextBrowser: No document for Kullan?m Ko?ullar?
  5. #20
    January 2012
    [3.0.16][Ubuntu] Keyboard does not work in teamspeak and microphone is disabled
    Hi
    I have a server with Ubuntu 14.04.2 and LXDE desktop.
    I installed Teamspeak version 3.0.16 64 bit.
    After I connect to the VNC and when I start teamspeak show in console:
    1. I can't use the keyboard in Teamspeak.
    2. When I join on my server, my microphone is disabled. In teamspeak Capture settings is Default.
    How can I fix this?
  6. #21
    April 2014
    is there any skilled admin ?
    @dante696 @Chris
    Keyboard layout & keyboard Turkish Q, Turkish, System lang also Turkish
    here is the terminal log again!
    2015-06-28 15:54:04.952413|INFO    |              |   | TeamSpeak 3 Client 3.0.16 (2014-08-04 13:42:43)
    2015-06-28 15:54:04.952536|INFO    |              |   | SystemInformation: Linux 3.16.0-41-generic #57~14.04.1-Ubuntu SMP Thu Jun 18 18:01:13 UTC 2015 x86_64 Binary: 64bit
    2015-06-28 15:54:04.952591|INFO    |              |   | Using hardware aes
    2015-06-28 15:54:04.965301|DEBUG   |PulseAudio    |   | connected to pulse audio server
    2015-06-28 15:54:04.990622|INFO    |              |   | Loading plugin: libappscanner_plugin
    2015-06-28 15:54:04.990695|INFO    |              |   | Loading plugin: libclientquery_plugin
    2015-06-28 15:54:04.990747|INFO    |              |   | Loading plugin: liblua_plugin
    2015-06-28 15:54:04.990784|INFO    |              |   | Loading plugin: libtest_plugin
    2015-06-28 15:54:04.992661|INFO    |Query         |   | listening on 127.0.0.1:25639
    2015-06-28 15:54:05.350502|INFO    |              |   | *** Time [MAINWINDOW]: 193
    2015-06-28 15:54:05.350649|INFO    |              |   | *** Time [INIT]: 194
    2015-06-28 15:54:05.353941|INFO    |ClientUI      |   | Failed to init text to speech engine
    2015-06-28 15:54:05.354028|INFO    |ClientUI      |   | Qt version: 5.2.1
    2015-06-28 15:54:05.354066|INFO    |ClientUI      |   | Using configuration location: /home/plazma/.ts3client/settings.db
    2015-06-28 15:54:05.851159|INFO    |ClientUI      |   | Last update check was: Paz Haz 28 15:15:10 2015
    how can we solve this problem on linux as users ?
  7. #22
    May 2012
    The 3rd dimension
    956
    Still cannot type in linux TeamSpeak 3 client.
    I know somewhere there is a thread about it but I cannot find it. I cannot believe after all this time of it being reported that I install TeamSpeak 3 client x64 on an Ubuntu VPS, this time not using LXDE desktop I am trying XFCE and it is doing the exact same thing. I cannot type anything in any TS client window area. Please can this get fixed already, the entire linux client is useless if you cannot type. You cannot enter your name, set bookmark labels, enter any passwords or anything at all. No typing is possible....
  8. #23
    March 2015
    56
    I tested the keywoard in Ubuntu 15.04 no work!
    CentOs 7 work correctly.
  9. #24
    April 2016
    I have almost same problem. I can type in ts3 client but the keymap is crazy, for example key "5" works as backspace, "q" printing "c" etc.
    Client (amd64) 3.0.19 running in tightvnc desktop, all other apps working fine, so for now I'm copy-pasting everything from mousepad to ts3client. Keyboard used - defender hb-520, locale ru_RU.UTF-8
    Qt: XKEYBOARD extension not present on the X server.
    Crashdump ENABLED,  directory is: /home/mk/.ts3client/crashdumps
    DUMP defined! Dumpdir is: /home/mk/.ts3client/crashdumps
    2016-04-14 11:01:09.270810|INFO    |              |   |TeamSpeak 3 Client 3.0.19 (2016-04-01 09:48:51)
    2016-04-14 11:01:09.271104|INFO    |              |   |SystemInformation: Linux 3.13.0-85-generic #129-Ubuntu SMP Thu Mar 17 20:50:15 UTC 2016 x86_64 Binary: 64bit
    2016-04-14 11:01:09.279429|DEBUG   |PulseAudio    |   |connected to pulse audio server
    2016-04-14 11:01:09.313248|INFO    |              |   |Loading plugin: libclientquery_plugin
    2016-04-14 11:01:09.313364|INFO    |              |   |Loading plugin: liblua_plugin
    2016-04-14 11:01:09.313395|INFO    |              |   |Loading plugin: libtest_plugin
    2016-04-14 11:01:09.314800|INFO    |Query         |   |listening on 127.0.0.1:25639
    2016-04-14 11:01:09.723435|INFO    |              |   |*** Time [MAINWINDOW]: 204
    2016-04-14 11:01:09.723789|INFO    |              |   |*** Time [INIT]: 204
    2016-04-14 11:01:09.733391|INFO    |ClientUI      |   |Failed to init text to speech engine
    2016-04-14 11:01:09.733520|INFO    |ClientUI      |   |Qt version: 5.5.1
    2016-04-14 11:01:09.733556|INFO    |ClientUI      |   |Using configuration location: /home/mk/.ts3client/settings.db
    2016-04-14 11:01:10.225227|INFO    |ClientUI      |1  |Connect to server: localhost
    2016-04-14 11:01:10.232665|INFO    |ClientUI      |1  |Trying to resolve localhost
    2016-04-14 11:01:10.235636|INFO    |ClientUI      |   |Last update check was: ## ###. 14 16:44:59 2016
    2016-04-14 11:01:10.236202|INFO    |TSDNS         |   |DNS resolve successful, "localhost"=127.0.0.1
    2016-04-14 11:01:10.236745|INFO    |              |   |Statistics report: Not yet, next report on ## ###. 29 17:05:07 2016
    2016-04-14 11:01:10.240412|INFO    |TSDNS         |   |SRV DNS resolve unsuccessful for "_ts3._udp.localhost"
    2016-04-14 11:01:10.240975|INFO    |ClientUI      |1  |Lookup finished: 127.0.0.1 9987 localhost 0 0
    2016-04-14 11:01:10.241021|INFO    |ClientUI      |1  |Resolve successful: 127.0.0.1:9987
    2016-04-14 11:01:10.241255|INFO    |ClientUI      |1  |Blacklist check ok
    2016-04-14 11:01:10.241294|INFO    |ClientUI      |1  |Initiating connection: 127.0.0.1:9987 localhost
    AA ts3.alsa.dummy.playbackdefault 5
    AA ts3.alsa.dummy.capturedefault 5
    2016-04-14 11:01:10.661904|INFO    |PreProSpeex   |1  |Speex version: 1.2rc1
    warning: The VAD has been replaced by a hack pending a complete rewrite
    2016-04-14 11:01:10.666630|INFO    |ClientUI      |1  |Connect status: Connecting
    2016-04-14 11:01:10.674141|DEVELOP |PktHandler    |   |Puzzle solve time: 8
    2016-04-14 11:01:10.680575|INFO    |ClientUI      |1  |Connect status: Connected
    2016-04-14 11:01:10.685073|INFO    |ClientUI      |1  |Connect status: Establishing connection
    2016-04-14 11:01:10.689949|INFO    |ClientUI      |1  |Connect status: Connection established
    2016-04-14 11:01:10.691347|INFO    |PermManager   |   |Loading permissions from cache
    2016-04-14 11:01:10.752955|INFO    |Newsticker    |   |Newsticker next check: ## ###. 14 18:15:19 2016
  10. #25
    April 2016
    Ok. When I changed my locale to en_US.utf8 I got next errors:
    Error:    Couldn't find file "rules/0" in include paths
    Error:    1 include paths searched:
    Error:          /usr/share/X11/xkb
    Error:    1 include paths could not be added:
    Error:          /home/mk/.xkb
    Error:    Couldn't look up rules '0', model 'pc105', layout 'us', variant '(null)', options ''
    So I linked my base xkb rules to "0"
    sudo ln -s /usr/share/X11/xkb/rules/base /usr/share/X11/xkb/rules/0
    sudo ln -s /usr/share/X11/xkb/rules/base.lst /usr/share/X11/xkb/rules/0.lst
    sudo ln -s /usr/share/X11/xkb/rules/base.xml /usr/share/X11/xkb/rules/0.xml
    and now I'm getting these errors:
    Qt: couldn't retrieve an initial keyboard state
    2016-04-14 18:33:30.254222|INFO    |              |   | TeamSpeak 3 Client 3.0.16 (2014-08-04 13:42:43)
    2016-04-14 18:33:30.254351|INFO    |              |   | SystemInformation: Linux 3.13.0-85-generic #129-Ubuntu SMP Thu Mar 17 20:50:15 UTC 2016 x86_64 Binary: 64bit
    2016-04-14 18:33:30.261423|DEBUG   |PulseAudio    |   | connected to pulse audio server
    2016-04-14 18:33:30.293411|INFO    |              |   | Loading plugin: libappscanner_plugin
    2016-04-14 18:33:30.293514|INFO    |              |   | Loading plugin: libclientquery_plugin
    2016-04-14 18:33:30.293543|INFO    |              |   | Loading plugin: liblua_plugin
    2016-04-14 18:33:30.293569|INFO    |              |   | Loading plugin: libtest_plugin
    2016-04-14 18:33:30.296392|INFO    |Query         |   | listening on 127.0.0.1:25639
    XIO:  fatal IO error 2 (### ###### ##### ### ########) on X server ":1.0"
          after 5 requests (5 known processed) with 0 events remaining.
    Looks like I should create some file with "initial keyboard state", but I'm not sure how should it look
  11. #26
    April 2016
    Finally.. That's all because TightVNC doesn't support XKB extension, required by qt. Instead of this tvnc using it's own crazy keymap
    keycode   8 = Control_L
    keycode   9 = Control_R
    keycode  10 = Shift_L
    keycode  11 = Shift_R
    keycode  12 = Meta_L
    keycode  13 = Meta_R
    keycode  14 = Alt_L
    keycode  15 = Alt_R
    keycode  16 = space
    keycode  17 = 0 parenright
    keycode  18 = 1 exclam
    keycode  19 = 2 at
    keycode  20 = 3 numbersign
    keycode  21 = 4 dollar
    keycode  22 = 5 percent
    keycode  23 = 6 asciicircum
    keycode  24 = 7 ampersand
    keycode  25 = 8 asterisk
    keycode  26 = 9 parenleft
    keycode  27 = minus underscore
    keycode  28 = equal plus
    keycode  29 = bracketleft braceleft
    keycode  30 = bracketright braceright
    keycode  31 = semicolon colon
    keycode  32 = apostrophe quotedbl
    keycode  33 = grave asciitilde
    keycode  34 = comma less
    keycode  35 = period greater
    keycode  36 = slash question
    keycode  37 = backslash bar
    keycode  38 = a A
    keycode  39 = b B
    keycode  40 = c C
    keycode  41 = d D
    keycode  42 = e E
    keycode  43 = f F
    keycode  44 = g G
    keycode  45 = h H
    keycode  46 = i I
    keycode  47 = j J
    keycode  48 = k K
    keycode  49 = l L
    keycode  50 = m M
    keycode  51 = n N
    keycode  52 = o O
    keycode  53 = p P
    keycode  54 = q Q
    keycode  55 = r R
    keycode  56 = s S
    keycode  57 = t T
    keycode  58 = u U
    keycode  59 = v V
    keycode  60 = w W
    keycode  61 = x X
    keycode  62 = y Y
    keycode  63 = z Z
    keycode  64 = BackSpace
    keycode  65 = Return
    keycode  66 = Tab
    keycode  67 = Escape
    keycode  68 = Delete
    keycode  69 = Home
    keycode  70 = End
    keycode  71 = Prior
    keycode  72 = Next
    keycode  73 = Up
    keycode  74 = Down
    keycode  75 = Left
    keycode  76 = Right
    keycode  77 = F1
    keycode  78 = F2
    keycode  79 = F3
    keycode  80 = F4
    keycode  81 = F5
    keycode  82 = F6
    keycode  83 = F7
    keycode  84 = F8
    keycode  85 = F9
    keycode  86 = F10
    keycode  87 = F11
    keycode  88 = F12
    keycode  89 = Insert
    keycode  90 = KP_Enter
    and all other codes are empty.
    So.. here comes the question - is it possible to run ts3client with specific keymap?
  1. How can I make TS3 respond to my laptop keyboard?
    By Aegisthus in forum General Questions
    Last Post: January 19th, 2014, 10:54 PM
  2. TS doesn't respond properly with mouse
    By johnenglish in forum Windows
    Last Post: March 19th, 2013, 01:33 PM
  3. TS3 doesn't respond to mouse/keyboard
    By Fast Forward in forum Client Support
    Last Post: January 14th, 2010, 04:02 PM
