Page 100 of 114 FirstFirst ... 50909899100101102110 ... LastLast
Results 1,486 to 1,500 of 1706
  1. #1486
    May 2018
    The Teamspeak 3 client crashed.
    Hello, only yesterday I encountered this problem. When I go to Teamspeak, he's crumbling. Re-installed a bunch of times, help. Windows 7 32-bit Click image for larger version.
  2. #1487
    June 2018
    Disconnected message in bottom right corner
    For some reason Teamspeak has decided to stop working.
    When i try to connect to any server it just says "failed to connect to server"
    I'm pretty sure its because it says "Disconnected" in the bottom right hand corner.
    Does anyone know why this is happening?
    Ive already disabled firewall, and reset my pc and router.
  3. #1488
    17,934
    Disconnected only tells you that you are not connected to a server in active tab.
    for the rest see post #1 in this thread
  4. #1489
    June 2018
    Nothing happens after the startup
    I downloaded TeamSpeak3 after downloading I tried to run TS3 and nothing happens. What should I do to make it work? I have a win 32 bit
  5. #1490
    June 2018
    TS3 Client x64 stürzt immer ab
    Hi Leute,
    seit den letzten Windows 10 x64 Updates diese Nacht, lässt sich mein TS3 nicht mehr starten.
    Habe einiges durch, Neuinstallation, Konfigurtation löschen ...
    In den Windows Ereignissen steht auch nichts und die TS3 DMP Dateien kann ich irgendwie auch nicht auslesen!
    Meine Hardware:
    CPU: i7-6700K
    MB: ASUS Z170 Pro Gaming
    RAM: 16GB DDR4
    GPU: ZOTAC AMP! GTX1060 6GB
    Soundcard: Soundblaster Z
  6. #1491
    March 2015
    7
    TS3 client crashes on startup
    Installed 64 bit on fresh windows 10 install and the client immediately crashes on startup.
    I have several other PCs running teamspeak and never had this issue.
    Would like to add a report or logfile but not sure how.
    Tried uninstalling and reinstalling 32 bit, same problem.
    I read somewhere that OpenGL on certain systems might not support teamspeak, i hope thats not the case?
    I am running it on an older pc than this one which is windows 7 and i have no problems there.
    Done all driver and windows updates.
    Any help would be greatly appreciated.
  7. #1492
    June 2018
    Cannot initialize connection on any channel
    I had this all working fine on my previous phone that I broke, re-downloaded it off google play and now I get failed connection initialization when I even try to join the Public TS server.
    Can someone lend a hand and let me know why this is,lol
    Thanks!
  8. #1493
    June 2018
    Sounds off.
    Hello I have a big problem... I have teamspeak for a long time... and now I when I update new TS3 3.1.9 I (I'm using win 10 latest update 1803) don't hear anything... And I don't know why... I tried use TS3 settings... but it's not work... When I connect to server I don't hear "Connected" and people in rooms too but other sounds in pc your internet I hear only TS3 not... Can you please help my how can I fix it?
  9. #1494
    January 2013
    Thüringen
    325
    Make sure that in Self -> playback profile the correct profile is checked.
    As for the sounds for connecting, they need to be enabled in the sound pack you have selected and the sound pack must be selected in self > sound pack.
  10. #1495
    June 2018
    i have the same problem. sound doesnt come off ts. everyone can hear me just fine, but i cant hear anything, not even from the client itself. sounds from games and music from the browser come off just fine.
    i have tried setting up every sound option possible, but nothing works.
  11. #1496
    June 2018
    Team Speak crash
    When I start my Team Speak it stops working and what appears in the image.
    Bug; http://prntscr.com/jtgwmw
    What should I do to solve
  12. #1497
    June 2018
    Teamspeak crash
    Since the new Teamspeak update I can't start Teamspeak anymore. I start it and it closes after 5 seconds and there's a error.
    It's been like that for days. I can't fix it I reinstalled it, deactivated my Anti-virus ans so on. I'm not sure if this is a bug but I need help. Hope you can help me...
  13. #1498
    March 2017
    10
    Connect status: Disconnected
    hellow
    i have such problem. i cant connect to server, but yesterday all work ok.
    this is log
    14.06.2018 06:00:56 ClientUI Info Connect to server: xxx.xxx.xxx.xxx
    14.06.2018 06:00:56 ClientUI Info Blacklist check ok
    14.06.2018 06:00:56 ClientUI Info Initiating connection: xxx.xxx.xxx.xxx:9987 xxx.xxx.xxx.xxx
    14.06.2018 06:00:57 ClientUI Info Connect status: Connecting
    14.06.2018 06:00:57 PktHandler Devel Puzzle solve time: 13
    14.06.2018 06:01:02 ClientUI Info Connect status: Disconnected
    14.06.2018 06:01:02 ClientUI Info Failed to connect to server, want autoreconnect = 0
    i try to connect with notebook, but problem same. whot can be a problem ?
  14. #1499
    June 2018
    Connection error
    Why i cant connect any server ts public also i cant join it why help me plz
  15. #1500
    June 2018
    TS3 not start on win7 32bit Home Premium
    Hello So I try are days desperate to install the TS3 client but directly after confirming the agb aborts the program. My configuration is: Windows 7 Home Premium 32bit made all ms updates. I just do not know next have already tried everything that there were so proposals in the network
  1. how refresh client information
    By 1230456 in forum Client Plugins / Lua Scripts
    Last Post: October 6th, 2015, 05:40 PM
  2. Can't delete or get client information from db
    By Barungar in forum General Questions
    Last Post: June 10th, 2013, 12:01 PM
  3. Windows client crashdump reports guided from origen
    By PotaBlava in forum Suggestions and Feedback
    Last Post: October 11th, 2012, 03:47 PM
#crash, #help, #help;c, #problem, #problem #playback, #ptt, #serverconnectingproblems, #teamspeak, #tshelp, #windows, 3.0.19, 3.1.3 random crash, absturz, access denied, android, android 5, android app, annoying, asap, audio problems, aufgehängt, avatar, blocked ip, bookmarks issues problem, bug, bug client querry order, bug error ts assistance, bug reports, bugg, bugs, can not connect, can't be heard, can't connect, can't connect to servers, can't hear, cannot connect anymore, cannot connect to server, cant conenct to server, cant connect, cant connect server, cant connect to server, cant hear anyone, cantconnect, clicking, client, client 3.1.6, client 3.1.9, confused, connect, connect and disconnect, connect to server, connect to server failed, connecting issues, connection, connection dropping, connection error, connection errors, connection failed, connection issue, connection issues, connection lost, connection problem, connection problems, could not connect, crash, crash bug, crash client, crash instant, crash on connect, crash on startup, crash options, crash report, crash start, crash teamspeak, crash to desktop, crashed, crashes, crashes client random, crashing, crashing issues with ts3, creators update, debug, developers, disconect, disconnect, dns, doesnt start, doesn´t work, domain, don´t start, download, drop, error, error 0xc0000142, error to connect, fail, failed, failed to conenct, failed to connect, failed to connect server, files, fix, freezes by pubg, games, gigabyte, headphones, headphones disabled, headset, headsets ts sound problem, help - npl issued, help asap, help can't hear, help me, help me please, help me pls, help needed, helpme, hilfe, hostname, hotkeys, how do i fix this, how to add bookmarks, idkwhatidid, important, initialisation, intel, ios, ip ports, iphone, iphone 6s, iphone problem, issue, issues, it's me please help me, join, joining server, kaputt, kein sound, living-bots, localhost, logs, loss, lua, lua plugin, mac, mac air, macbookpro, mdi, mic, mic auto mutes, mic disabled, mic issues, mic not working, mic works no sound, mic.help.support.client, michrophone, microfon inaktiv, microphone, microphone deactivated, microphone disabled, microphone mute, microphone problem, microphone work error, mikrofon deaktiviert, mikrofon probleme, mobile, mute, mutes sound, need help!, neuinstallation, new internet, new user, nix hören, no connection, no response, no sound, no sound playback, no sound when ts 3 open, no start, not able to connect, not able to use, not responding, not starting, not working, nvidia, opens and then closes, options, overwolf. overlay., packet, perfect with windows 8, perm, perm manager, playback problem, please fix, please help, pls help, problem, problem connect server, problem on launch, problem starting, problem to connect, problems, push to talk wont work, random, reasoning?, recording tool, report, reports, router, server, server address, server connection, server connnection, server error, server help, server issue, server list, server problem, serverlist, servers, single, sound, sound disabled, speaker off, speakers, speakers disabled, specific server, staff, start, startet nicht, startup, stopped working, stopping ts, stürzt ab, suddenly, support, support system, team speak 3, team speak 3.1.6.0, team speak error, team speak giving crash, teamspeak, teamspeak 3, teamspeak 3 64bit, teamspeak 3 client, teamspeak 3 error, teamspeak crash, teamspeak error, teamspeak microphone, teamspeak3, teamspeak3 crash, teamspeak3 support, teamspekproblem, tried everything, ts3, ts3 client problem, ts3 connection problem, ts3 crash, ts3 problems, ucrtbase.dll, ultimate, unable to connect, unresponsive, update, update bug, upload, urgent, verbindungsproblem, what to do, wi-fi. connection. error., wifi, windows, windows 10, windows 10 64bit, windows 7, windows 8, windows 8.1 64-bit, windows10, won't open, won´t start, zufällig, [security update]
View Tag Cloud
