Page 113 of 114 FirstFirst ... 1363103111112113114 LastLast
Results 1,681 to 1,695 of 1706
  1. #1681
    April 2019
    Verbindung zum Server fehlgeschlagen nach Update
    Hallo,
    Nach einem Update ist es mir nun nicht mehr möglich auf private Server zu joinen.
    Ca. 7 Sekunden nach dem Verbindungsversuch kommt die Meldung Error und Verbindung zum Server fehlgeschlagen.
    Bei den Teamspeak Public Servern und den in der Server Liste ist connecten jedoch problemlos möglich.
    Ich habe schon mehrere Neustarts und neu Installationen gemacht ohne Erfolg.
    Danke schonmal im Voraus.
  2. #1682
    April 2019
    Can't connect to any Teamspeak server
    I have downloaded Teamspeak 3 Client, but I can't connect to a teamspeak Server anyway. Teamspeak has already a permission for my Firewall so, I don't know why Teamspeak still doesn't connect me to a Teamspeak Server. Can somebody please give me a hint?
    Regards
    Alex
  3. #1683
    May 2019
    TeamSpeak 3 Crashes
    Hello. I really need your help. The program crashes after launch. Tried to reinstall, removing with the ccleaner and tried to install other versions, but it did not work. Advise something please.
  4. #1684
    May 2019
    My teamspeak freezes when opening
    When I open my teamspeak it freezes and it wont let me click or do anything else!
    If u want the proof/recording you can add me on advert removed
    PLEASE HELP
  5. #1685
    May 2019
    Teamspeak keeps crashing
    Hello.
    My Teamspeak 3 keeps crashing since a while.
    It runs for a couple of seconds but it crashes then.
    I've already uninstalled it (also the configs) and installed 64Bit and 32 Bit versions but the same problem appeared.
  6. #1686
    May 2019
    Teamspeak Crashes
    I downloaded the teamspeak version 3.2.5 and i installe it but when i opened it crashed.
    How can i fix this anyone knows?
  7. #1687
    May 2019
    Hot keys dont work on servers
    I formatted my pc and when I set up new shortcut keys I realized that they just do not work when I'm logged on to a server. I dont know what to do.
  8. #1688
    17,939
    Please read the beginning post # 1 in this thread and then scroll to You have problem with your hotkey or hotkeys?
    Hope this helps you out.
  9. #1689
    February 2018
    TS3 Crashes after 20 - 30 secs after joiining ONLY THIS ONE SERVER
    Problem:
    TS3 is crashing when joinging this specific one server im using for Arma 3 RP.
    I am the ONLY one with this problem.
    i tested 2 things.
    I am connecting to my server.
    No problems, after 2 hours no crash.
    I disconnect and connect to my Arma 3 TS, CRASH!
    I disabled EVERY Plugin.
    Still crash occurs.
    Im using the newest version of TS3.
    Any suggestions?
  10. #1690
    June 2019
    ich kan mich nicht mit dem server verbinden
    jedes mal wen ich mich mit dem Server verbinden will kommt die Nachricht Verbindung zum Server felgeschlagen.
  11. #1691
    June 2019
    Client crashes after a few seconds (Windows 10)
    When i start TS3, afeter a few seconds (10, 15)it crashes. I can hear my friends voices but my mic doens't work and the client is frozen, i can't even close it. Just ctrl + alt + del works to close the program. Ive already tried to reinstall, update windows and audio drivers.
  12. #1692
    17,939
    Myguess without any log or hardware detauls is that you own a ASUS GPU and have Asus GPU Tweak running.
    That software causes the freeze in that case.
    https://forum.teamspeak.com/threads/137976
  13. #1693
    July 2018
    Connection dropping every 30minutes
    Hi community,
    Recently I've got a real problem with TeamSpeak as I described it in the topic title. The only solution I found is that I must close TeamSpeak then reopen it.
    This is so annoying when we are playing a game as a team so I can't communicate with my team.
  14. #1694
    June 2019
    Mein Headset wird nicht erkannt...
    Hallo liebes Ts3 Team, mein Name ist André und ich habe ein Problem mit meinem Headset,ich habe es bereits als Standardgerät und Kommunikationsstandard eingestellt doch es wird nicht erkannt bzw (Ts3) bei Aufnahme/Wiedergabe steht nur "Standart" obwohl ich mehrere Mik. angeschlossen habe.
    Bitte Helfen sie mir
    Lg.: André | TodleTodle
    email: insuppe***********
  15. #1695
    June 2019
    Cannot use push to talk
    I have recently change to windows 10 and now unfortunately I can no longer use push to talk. I am running in administrator mode and my mic works fine in voice activation mode. I have tried to update TS and haven't been able to find a solution. Any ideas?
  1. how refresh client information
    By 1230456 in forum Client Plugins / Lua Scripts
    Last Post: October 6th, 2015, 05:40 PM
  2. Can't delete or get client information from db
    By Barungar in forum General Questions
    Last Post: June 10th, 2013, 12:01 PM
  3. Windows client crashdump reports guided from origen
    By PotaBlava in forum Suggestions and Feedback
    Last Post: October 11th, 2012, 03:47 PM
#crash, #help, #help;c, #problem, #problem #playback, #ptt, #serverconnectingproblems, #teamspeak, #tshelp, #windows, 3.0.19, 3.1.3 random crash, absturz, access denied, android, android 5, android app, annoying, asap, audio problems, aufgehängt, avatar, blocked ip, bookmarks issues problem, bug, bug client querry order, bug error ts assistance, bug reports, bugg, bugs, can not connect, can't be heard, can't connect, can't connect to servers, can't hear, cannot connect anymore, cannot connect to server, cant conenct to server, cant connect, cant connect server, cant connect to server, cant hear anyone, cantconnect, clicking, client, client 3.1.6, client 3.1.9, confused, connect, connect and disconnect, connect to server, connect to server failed, connecting issues, connection, connection dropping, connection error, connection errors, connection failed, connection issue, connection issues, connection lost, connection problem, connection problems, could not connect, crash, crash bug, crash client, crash instant, crash on connect, crash on startup, crash options, crash report, crash start, crash teamspeak, crash to desktop, crashed, crashes, crashes client random, crashing, crashing issues with ts3, creators update, debug, developers, disconect, disconnect, dns, doesnt start, doesn´t work, domain, don´t start, download, drop, error, error 0xc0000142, error to connect, fail, failed, failed to conenct, failed to connect, failed to connect server, files, fix, freezes by pubg, games, gigabyte, headphones, headphones disabled, headset, headsets ts sound problem, help - npl issued, help asap, help can't hear, help me, help me please, help me pls, help needed, helpme, hilfe, hostname, hotkeys, how do i fix this, how to add bookmarks, idkwhatidid, important, initialisation, intel, ios, ip ports, iphone, iphone 6s, iphone problem, issue, issues, it's me please help me, join, joining server, kaputt, kein sound, living-bots, localhost, logs, loss, lua, lua plugin, mac, mac air, macbookpro, mdi, mic, mic auto mutes, mic disabled, mic issues, mic not working, mic works no sound, mic.help.support.client, michrophone, microfon inaktiv, microphone, microphone deactivated, microphone disabled, microphone mute, microphone problem, microphone work error, mikrofon deaktiviert, mikrofon probleme, mobile, mute, mutes sound, need help!, neuinstallation, new internet, new user, nix hören, no connection, no response, no sound, no sound playback, no sound when ts 3 open, no start, not able to connect, not able to use, not responding, not starting, not working, nvidia, opens and then closes, options, overwolf. overlay., packet, perfect with windows 8, perm, perm manager, playback problem, please fix, please help, pls help, problem, problem connect server, problem on launch, problem starting, problem to connect, problems, push to talk wont work, random, reasoning?, recording tool, report, reports, router, server, server address, server connection, server connnection, server error, server help, server issue, server list, server problem, serverlist, servers, single, sound, sound disabled, speaker off, speakers, speakers disabled, specific server, staff, start, startet nicht, startup, stopped working, stopping ts, stürzt ab, suddenly, support, support system, team speak 3, team speak 3.1.6.0, team speak error, team speak giving crash, teamspeak, teamspeak 3, teamspeak 3 64bit, teamspeak 3 client, teamspeak 3 error, teamspeak crash, teamspeak error, teamspeak microphone, teamspeak3, teamspeak3 crash, teamspeak3 support, teamspekproblem, tried everything, ts3, ts3 client problem, ts3 connection problem, ts3 crash, ts3 problems, ucrtbase.dll, ultimate, unable to connect, unresponsive, update, update bug, upload, urgent, verbindungsproblem, what to do, wi-fi. connection. error., wifi, windows, windows 10, windows 10 64bit, windows 7, windows 8, windows 8.1 64-bit, windows10, won't open, won´t start, zufällig, [security update]
View Tag Cloud
