Page 117 of 118 FirstFirst ... 1767107115116117118 LastLast
Results 1,741 to 1,755 of 1757
  1. #1741
    October 2019
    Teamspeak does not recognize my headset
    I have a HyperX Cloud Alpha Everything else is working but in teamspeak I can't hear anything since recently. I don't know why. It's only in TS so with all the other applications it works. I don't have a soundcard.
    IM sorry for bad inglisch I am German .
    Tanks Marvin
  2. #1742
    October 2019
    TeamSpeak closing by itself.
    This problem started today, I clicked on the options to try to change the key that was pressed to speak, but teamspeak was closed. I reinstalled it and now I can't even log in to myTeamspeak because it closes on the Accept Terms tab. Solution?
  3. #1743
    November 2019
    Interesting Microphone Problem
    Hi!
    My problem is a little longer story. I have a working headset that worked well in teamspaces until I reinstalled my computer. There has never been such a problem, but since then I hear it everywhere when I speak in the microphone except here in teamspeak. I tested the settings there, in principle it senses, but neither at the touch of a button nor in the automatic voice recognition players hear. Currently, due to the new speaker, my headset is plugged into the front jack and I can hear +10 decibels on any other device and programs. I can pull it up here even if no one hears. What could be the problem?
  4. #1744
    November 2019
    Cannot connect to certain servers
    Its quite simple and odd, certain servers work always for me and some of them don't. In order to join a server that i cannot join i have to restart TS3 2-5 times and try to connect, but after those restarts i'm able to connect. Has happened for quite some time and reinstalling TS doesn't fix it. Let me know what information you need to solve this problem
  5. #1745
    November 2019
    Kann nicht auf Ts5 Server und update Benachrichtigung aber kein Update verfügbar
    Ich kann mit meiner Android App v3.3.2 nicht auf den von mir in Ts5 erstellten Server joinen. Dessweiteren bekomme ich beim starten der app die Meldung das ein Update verfügbar sei welches im playstore nicht zu finden ist. Click image for larger version.
  6. #1746
    November 2019
    Help please TSDNS or idk..
    I cant connect to any server..Click image for larger version.
  7. #1747
    November 2019
    Pascual Yunquera, 9
    Teamspeak 3 Client doesn't want to open
    why teamspeak 3 client doesnt want to open?
  8. #1748
    November 2019
    España
    Team speak not working on my Mac
    It worked just fine when I used windows, but now I am unable to use it on mac. It doesn't open. Is there any compatibility issue or something?
  9. #1749
    December 2019
    TS3 keeps disconnecting.
    As I connect to the servers I previously have been able to connect, it connects for 3-4 seconds and then disconnects. This happens on every server I try to connect.
    Client Log keeps spamming something like this untill I disconnect from all servers.
    10.12.2019 14:10:13 PktHandler Devel Puzzle solve time: 3
    10.12.2019 14:10:18 ClientUI Info Connect status: Disconnected
    10.12.2019 14:10:18 ClientUI Info Failed to connect to server, want autoreconnect = 1
    10.12.2019 14:10:19 ClientUI Info Autoreconnecting
    10.12.2019 14:10:19 ClientUI Info Connect to server: zapador.net
    10.12.2019 14:10:19 ClientUI Info Trying to resolve zapador.net
    10.12.2019 14:10:19 TSDNS Info A/AAAA DNS resolve successful, "zapador.net" =(h: 148.251.66.220 p:0)
    10.12.2019 14:10:19 TSDNS Info A/AAAA DNS resolve for possible TSDNS successful, "zapador.net" =(h: 148.251.66.220 p:0)
    10.12.2019 14:10:19 TSDNS Info SRV DNS resolve unsuccessful, "_tsdns._tcp.zapador.net" The resolved dns name produced no (usable) records
    10.12.2019 14:10:19 TSDNS Info SRV DNS resolve unsuccessful, "_ts3._udp.zapador.net" The resolved dns name produced no (usable) records
    10.12.2019 14:10:21 TSDNS Info TSDNS queried unsuccessfully 148.251.66.220:41144
    10.12.2019 14:10:21 TSDNS Info No TSDNS found
    10.12.2019 14:10:21 ClientUI Info Lookup finished: ip=148.251.66.220 port=9987 query=zapador.net error=0
    10.12.2019 14:10:21 ClientUI Info Resolve successful: 148.251.66.220:9987
    10.12.2019 14:10:21 ClientUI Info Initiating connection: 148.251.66.220:9987
    10.12.2019 14:10:21 ClientUI Info Connect status: Connecting
    10.12.2019 14:10:21 PktHandler Devel Puzzle solve time: 4
  10. #1750
    December 2019
    Failed to connect to the server's name
    I can't join the server I want, there is a problem, help me
  11. #1751
    December 2019
    teamspeak crash
    okay so i play fivem and the server i play on requires tokovoip, it used to work fine but out of nowhere when i join the server now and open teamspeak, teamspeak automatically crashes. teamspeak works fine when im not on the server. please help
  12. #1752
    December 2019
    overwolf
    HAVING TROUBLE WITH OVER WOLF,OVER LAY. WHEN I INSTALL IT. I GET THIS MESSAGE : COUDN'T LOAD EXTENION- MISSING DIRECTORG. NO MATTER HOW MANY TIMES YOU DOWN LOAD IT. YOU GET THIS MESSAGE. IF YOU TAKE OFF OVER WOLF, RELOAD IT WILL WORK, BUT WHEN YOU COME BACK ON YOUR PC. IT SCREW EVER THING UP-YAHOO.COM ALL OF IT. BUT YOU TAKE IT OFF EVER THING STARTS WORKING AGAIN.:
  13. #1753
    December 2019
    DCS trouble
    I am new to teamspeak and I am trying to use it with DCS. Digital Combat Simulator. Teamspeak mutes DCS. Any ideas what setting might be causing this? Thank you for your expertise, sincerely, kw993
  14. #1754
    January 2020
    Teamspeak crashes when joining server
    no matter what server I join my team speak crashes upon joining. I can sit in a room with no problem but when I join the server it crashes someone help. New to teamspeak
  15. #1755
    January 2020
    TS3 Connection Issue
    Recently (2 days ago) my power dupply died a horrible death and I had to replace it. And to my surprise for some unknown reason my Teamspeak cannot connect to any known server. I have no idea how can this be connected to power supply but that was the the event after which ts3 stopped working. Everything else works perfectly, didn't notice any problems while using any other voice comms, no changes were made except for replacing my PCs power supply. Ts3 notifies me that he failed to connect to the server.
    I hope someone can help me
There are currently 3 users browsing this thread. (0 members and 3 guests)
  1. how refresh client information
    By 1230456 in forum Client Plugins / Lua Scripts
    Last Post: October 6th, 2015, 06:40 PM
  2. Can't delete or get client information from db
    By Barungar in forum General Questions
    Last Post: June 10th, 2013, 01:01 PM
  3. Windows client crashdump reports guided from origen
    By PotaBlava in forum Suggestions and Feedback
    Last Post: October 11th, 2012, 04:47 PM
#crash, #headset, #help, #help;c, #problem, #problem #playback, #ptt, #serverconnectingproblems, #teamspeak, #tshelp, #windows, 3.0.19, 3.1.3 random crash, 5mm, 64 bit, absturz, access denied, android, android 5, android app, annoying, asap, audio problems, aufgehängt, avatar, blocked ip, bookmarks issues problem, bug, bug client querry order, bug error ts assistance, bug reports, bugg, bugs, can not connect, can't be heard, can't connect, can't connect to servers, can't hear, cannot connect anymore, cannot connect to server, cant conenct to server, cant connect, cant connect server, cant connect to server, cant hear anyone, cantconnect, clicking, client, client 3.1.6, client 3.1.9, client 3.3.2, conenction issue, confused, connect, connect and disconnect, connect to server, connect to server failed, connecting issues, connection, connection dropping, connection error, connection errors, connection failed, connection issue, connection issues, connection lost, connection problem, connection problems, could not connect, crash, crash bug, crash client, crash error 3.3.0, crash instant, crash on connect, crash on startup, crash options, crash report, crash start, crash teamspeak, crash to desktop, crashed, crashes, crashes client random, crashing, crashing issues with ts3, creators update, debug, developers, disconect, disconnect, dns, doesn't download, doesnt start, doesn´t work, domain, don´t start, download, drop, error, error 0xc0000142, error to connect, fail, failed, failed to conenct, failed to connect, failed to connect server, files, fix, freezes by pubg, front panel, games, gigabyte, headphones, headphones disabled, headset, headsets ts sound problem, help - npl issued, help asap, help can't hear, help me, help me please, help me pls, help needed, helpme, hilfe, hostname, hotkeys, how do i fix this, how to add bookmarks, idkwhatidid, important, initialisation, intel, ios, ip ports, iphone, iphone 6s, iphone problem, issue, issues, it's me please help me, jack 3, join, joining server, kaputt, kein sound, living-bots, localhost, logs, loss, lua, lua plugin, mac, mac air, macbookpro, mdi, mic, mic auto mutes, mic disabled, mic issues, mic not working, mic works no sound, mic.help.support.client, michrophone, microfon inaktiv, microphone, microphone deactivated, microphone disabled, microphone mute, microphone problem, microphone work error, mikrofon deaktiviert, mikrofon probleme, mobile, mute, mutes sound, my microphone problem, need help!, neuinstallation, new internet, new user, nix hören, no connection, no log, no response, no sound, no sound playback, no sound when ts 3 open, no start, not able to connect, not able to use, not responding, not starting, not working, nvidia, opens and then closes, options, overwolf. overlay., packet, perfect with windows 8, perm, perm manager, playback problem, please fix, please help, pls help, problem, problem connect server, problem on launch, problem starting, problem to connect, problems, push to talk wont work, random, reasoning?, recording tool, report, reports, router, server, server address, server connection, server connnection, server error, server help, server issue, server list, server problem, serverlist, servers, single, somehow i fucked it up, sound, sound disabled, speaker off, speakers, speakers disabled, specific server, staff, start, startet nicht, startup, stopped working, stopping ts, stürzt ab, suddenly, support, support system, team speak 3, team speak 3.1.6.0, team speak error, team speak giving crash, teamspeak, teamspeak 3, teamspeak 3 64bit, teamspeak 3 client, teamspeak 3 error, teamspeak crash, teamspeak error, teamspeak microphone, teamspeak3, teamspeak3 crash, teamspeak3 support, teamspekproblem, technical support, technicalhelp, tried everything, ts3, ts3 client problem, ts3 connection problem, ts3 crash, ts3 problems, ucrtbase.dll, ultimate, unable to connect, unresponsive, update, update bug, upload, urgent, verbindungsproblem, volume control, what to do, wi-fi. connection. error., wifi, windows, windows 10, windows 10 64bit, windows 7, windows 8, windows 8.1 64-bit, windows10, won't open, won´t start, zufällig, [security update]
View Tag Cloud
