Page 56 of 118 FirstFirst ... 646545556575866106 ... LastLast
Results 826 to 840 of 1761
  1. #826
    March 2015
    Macbook Pro- I can hear others, but no sound from me.
    I have been using TS for a few months successfully. Now, others see me, but cannot hear me. I can hear others, but they cannot hear me.I'm a newer Macbook Pro user. Doesn't matter with headset or speakers.
  2. #827
    April 2014
    Same problem here for two of my friends. These problems seem to stack up since about a month... Hopefully there will be a solution soon.
  3. #828
    March 2015
    Microphone Disabled on its own?
    Hi guys I have been using team speak for years and love it! I recently got a new computer and for some reason my microphone is disabled automatically by ts3, only way for it to work for me is if i close and reopen it.
    If i click the "activate microphone" button it instantly disables my microphone right after...PLEASE help I like ts3 and use it alot but cant open and reopen in games so much. :l
    THANKS!!!!!!!!
    Also, i just uninstalled and re-installed ts3 and the problem still persists. I also checked all of my hotkeys to make sure I wasn't pushing anything to make the mic disable. only hotkey was my ptt (F) thanks for taking the time to look. I look forward to any advice!
  4. #829
    March 2015
    Mic problems
    My mic isnt working on teamspeak at all. I unplugged my mic and tested with my computer mic, didnt work, messed through every possible setting combination restarted my computer, deleted and reinstalled TS3. The blue light does not light up for me and no one can hear me. My mic does work as i tested it on skype and so does the mic built in m computer please help me fix my microphone issue
  5. #830
    March 2015
    Help me my ts keeps shuting down
    C:\Users\landyn\Documents\ts3_clientui-win64-1407159763-2015-03-16 16_40_25.457206.dmp
  6. #831
    March 2015
    Unable to Broadcast
    I have encountered a problem that caused my TS3 client to stop broadcasting. It was working fine up until yesterday. Thus far, I have reinstalled the program, restarted my computer, and tinkered with the capture settings. I am out of ideas and am wondering if anyone else has encountered this, and how they went about resolving this.
  7. #832
    March 2015
    Cant connect to a specific server
    So today i change my router to a better one. I was talking to some one before the router was changed and everything was okay, then the router was changed and wouldn't let me join the server. I tried another public server and I was able to join with no problem. Then I connected my PC with my cellphones hot spot and I was able to join the server, once I was in the server I changed back to my router and I was able to stay connected on the server. Until now this is the only server showing this problem, and it bothers me because its the one my friend bought and we talk with many people in it. Is there anyway I can fix this?
  8. #833
    4,368
    If you do not even provide the IP:Port, we will not help you.
  9. #834
    2,698
    Quote Originally Posted by Ghostblue27 View Post
    Ok, you can't connect to the server but ... what message do you get then?
    If you have a dynamic public IP maybe the new public IP after changing the router is filtered or blocked by the server host firewall or banned by the server admin. Try restarting the router, this will give you a new IP.
  10. #835
    March 2015
    im having a similar issue. Doesnt work on any of my computers but works for all my friends.
  11. #836
    April 2014
    9
    TeamSpeak Won't Connect to server
    I am using XP. I have TS 3.0.2 /4.7.2 installed. I used the bookmark option to put the hovercontrol address in. When I try to connect it only goes as far as trying to connect to hovercontrol. This was a fresh install of TS.
  12. #837
    18,513
    Please update your client first (latest version is 3.0.16), we do not give support for outdated software.
    http://www.teamspeak.com/?page=downloads
  13. #838
    March 2015
    I cant hear anything
    I'm using TS3 in wow and cant hear a damn thing. I have done all the recommendations posted. Changed communications to do nothing... etc but still no luck. I cant even hear test sounds... any help please.
  14. #839
    March 2015
    Cant connect to server
    I need your help. I can not connect to any server. It writes me only Failed to connect to server and says me ERROR, please help me. Thanks for any feedback.
  15. #840
    March 2015
    Some people cant join my hosted teamspeak server.
    Hey,
    First of all im sry about my bad english
    me and my friends bought 1 week ago a host for our Ts (from tserverhq for 30 slots)
    the host work fine we even met new friends and all good.
    then i publish it on community forum on my country and some people said that they cant join in.
    i added one of them on skype so he can screen share me and i will what the problem.
    and its loading the ts like normal
    "Trying to resolve hostname <IP>"
    "Trying to connect to server on <IP>"
    but instead to enter the server its just "Failed to connect to server"
    and its really annoying that only some people can join and some people cant join.
    i really will loved for help
    and Tnx for the answers .
  1. how refresh client information
    By 1230456 in forum Client Plugins / Lua Scripts
    Last Post: October 6th, 2015, 06:40 PM
  2. Can't delete or get client information from db
    By Barungar in forum General Questions
    Last Post: June 10th, 2013, 01:01 PM
  3. Windows client crashdump reports guided from origen
    By PotaBlava in forum Suggestions and Feedback
    Last Post: October 11th, 2012, 04:47 PM
#crash, #headset, #help, #help;c, #problem, #problem #playback, #ptt, #serverconnectingproblems, #teamspeak, #tshelp, #windows, 3.0.19, 3.1.3 random crash, 5mm, 64 bit, absturz, access denied, android, android 5, android app, annoying, asap, audio problems, aufgehängt, avatar, blocked ip, bookmarks issues problem, bug, bug client querry order, bug error ts assistance, bug reports, bugg, bugs, can not connect, can't be heard, can't connect, can't connect to servers, can't hear, cannot connect anymore, cannot connect to server, cant conenct to server, cant connect, cant connect server, cant connect to server, cant hear anyone, cantconnect, clicking, client, client 3.1.6, client 3.1.9, client 3.3.2, conenction issue, confused, connect, connect and disconnect, connect to server, connect to server failed, connecting issues, connection, connection dropping, connection error, connection errors, connection failed, connection issue, connection issues, connection lost, connection problem, connection problems, could not connect, crash, crash bug, crash client, crash error 3.3.0, crash instant, crash on connect, crash on startup, crash options, crash report, crash start, crash teamspeak, crash to desktop, crashed, crashes, crashes client random, crashing, crashing issues with ts3, creators update, debug, developers, disconect, disconnect, dns, doesn't download, doesnt start, doesn´t work, domain, don´t start, download, drop, error, error 0xc0000142, error to connect, fail, failed, failed to conenct, failed to connect, failed to connect server, files, fix, freezes by pubg, front panel, games, gigabyte, headphones, headphones disabled, headset, headsets ts sound problem, help - npl issued, help asap, help can't hear, help me, help me please, help me pls, help needed, helpme, hilfe, hostname, hotkeys, how do i fix this, how to add bookmarks, idkwhatidid, important, initialisation, intel, ios, ip ports, iphone, iphone 6s, iphone problem, issue, issues, it's me please help me, jack 3, join, joining server, kaputt, kein sound, lauching, living-bots, localhost, logs, loss, lua, lua plugin, mac, mac air, macbookpro, mdi, mic, mic auto mutes, mic disabled, mic issues, mic not working, mic works no sound, mic.help.support.client, michrophone, microfon inaktiv, microphone, microphone deactivated, microphone disabled, microphone mute, microphone problem, microphone work error, mikrofon deaktiviert, mikrofon probleme, mobile, mute, mutes sound, my microphone problem, myteamspeak, need help!, neuinstallation, new internet, new user, nix hören, no connection, no log, no response, no sound, no sound playback, no sound when ts 3 open, no start, not able to connect, not able to use, not responding, not starting, not working, nvidia, opens and then closes, options, overwolf. overlay., packet, perfect with windows 8, perm, perm manager, playback problem, please fix, please help, pls help, problem, problem connect server, problem on launch, problem starting, problem to connect, problems, push to talk wont work, random, reasoning?, recording tool, report, reports, router, server, server address, server connection, server connnection, server error, server help, server issue, server list, server problem, serverlist, servers, single, somehow i fucked it up, sound, sound disabled, speaker off, speakers, speakers disabled, specific server, staff, start, startet nicht, startup, stopped working, stopping ts, stürzt ab, suddenly, support, support system, team speak 3, team speak 3.1.6.0, team speak error, team speak giving crash, teamspeak, teamspeak 3, teamspeak 3 64bit, teamspeak 3 client, teamspeak 3 error, teamspeak crash, teamspeak error, teamspeak microphone, teamspeak3, teamspeak3 crash, teamspeak3 support, teamspekproblem, technical support, technicalhelp, tried everything, ts3, ts3 client problem, ts3 connection problem, ts3 crash, ts3 problems, ucrtbase.dll, ultimate, unable to connect, unresponsive, update, update bug, upload, urgent, verbindungsproblem, volume control, what to do, wi-fi. connection. error., wifi, windows, windows 10, windows 10 64bit, windows 7, windows 8, windows 8.1 64-bit, windows10, won't open, won´t start, zufällig, [security update]
View Tag Cloud
