Originally Posted by
tiga05
I tried the fix in the first post, but I only get an error when I type the command "use port=ANY_ACTIVE_PORT": error id=1540 msgconvert\serror.
So I repeated this (and the other command) with the default port 9987 and it worked. So.... I think this is now only fixed for the server with the port "9987"? What does this error mean, when I try to use all ports?
It's a place holder, since we cannot know which ports are being used on your installation. It written in caps to indicate it being a place holder. Given that it says "any" it doesn't matter which one you use as long as it's an active server.
The command will actually fix it on all virtual servers, current and future ones.
Barungar
You can't use "any_active_port"; it's just a place holder in the posting. You'll have to repeat the steps for any active server/port combination.
No you don't. The command will fix all virtual servers in the instance.
Soluna
Will there be an official fix or how can we get rid of this? Itīs really annoying and it feels as if the users receive this spam at increasingly shorter intervals
New installations are not affected for over 2 years. Old instances are because there wasn't an easy way for us to fix those while not potentially messing up user made changes to the group.
So if your instance is old you have to change the permissions once by running the command(s) indicated in the announcement as well as the first post of this thread. Or the ones posted by ScP a couple of posts up, which do the exact same thing as those in the first post. He just split them up and used a different command not requiring to select a specific server.
