Page 1 of 2 12 LastLast
Results 1 to 15 of 21
    March 2013
    Connected clients have same IP as server.
    Hi
    I have a teamspeak 3 server running on one of my old laptop's which I don't use anymore. When I created my first teamspeak 3 server everything was running fine.
    But now a few month ago, everybody on the server flag's stop working. The flag icon is still there, but it is the South African flag. The server is in South Africa.
    No I have notice that everybody on the server have the same ip address, and the ip address is the server ip address. Now to me this is weird because we have clients from all over the world. And they are not sitting in my house so that they can be behind the router.
    I am thinking that because of the ip address problem, this is why everybody on the server have the same flag, the South Africa flag, as the ip address in located in South Africa.
    I would like to resolve this problem, but I do not know what to do. I will give the details about the server
    Server
    CPU: AMD Athlon 64
    RAM:1 GB
    OS:Windows Professional
    OS State:Running in Safe Mode with Networking
    Firewall:Allowing all out and incoming connection for Teamspeak. Windows Firewall
    December 2005
    164
    I've not tried this, but maybe if you are using your server as a router to connect your computers to your internet connection, this can be normal through Network Address Translation. Did you have tried to connect to your teamspeak server using your public IP instead of the local address? If you connect through it, you should be able to see the normal IPs and flags if this is the problem.
    March 2013
    Quote Originally Posted by Bloodsoul View Post
    Thank you for your reply. I don't think it could be the problem as the server are connected to the DSL Modem downstairs in my house.
    I have an LAN cable running from downstairs up into my bedroom, where my personal PC is and the server is. This LAN cable then get's split by a small D-Link Ethernet Switch. So the server is still connected to the router.
    Because of my ISP I don't get a static IP address, so I use a DDNS service.
    I will also give the ISP a call today about this. I will update here if I get any news from them
    Hope that this new information is helpful.
    Greetings
    Grant
    May 2014
    Hii. I have just setup a TS3 server for windows at my home. Everything is working fine. Clients are able to connect to the server from outside the network using a dyn dns service. But when I checked the client connection info and the server log I noticed that all my clients are getting the local ip address of my local network.
    (e.g. 10/5/2014 7:52 PM VirtualServerBaseInfo client connected 'john (id:23) from 192.168.0.1:8596)
    It seems that the server is unable to resolve my clients' wan ip addresses. May you please help me show some solutions. Thanks
    December 2004
    RF
    3,008
    This means you are incorrectly set up the gateway that redirect traffic to the TS server.
    May 2014
    ok I have set up my statip ip address like this
    IP address: 192.168.0.10
    subnet: 255.255.255.0
    gateway: 192.168.0.1
    this gateway is the router's ip addresss.
    pls how do you supposed i set this up?
    I have also noticed this warning on my server log:
    11/5/2014 12:35 AM TSDNS Warning getaddrinfo error: The requested name is valid, but no data of the requested type was found.
    11/5/2014 12:35 AM PktHandler Devel Puzzle solve time: 7
    11/5/2014 12:36 AM PktHandler Devel Puzzle solve time: 20
    11/5/2014 12:38 AM PktHandler Devel Puzzle solve time: 18
    11/5/2014 12:39 AM PktHandler Devel Puzzle solve time: 7
    December 2004
    RF
    3,008
    Quote Originally Posted by andruso101 View Post
    You have error in router configuration.
    Don't use TSDNS...
    May 2014
    I am not using TSDNS. Can pls tell me which setting in the router that needs to be changed. Thanks
    April 2009
    173
    HI Andruso101
    So i tested the Portforwarding.
    My settings are :
    Protocoll: UDP
    Port: 9887
    Internal Ip: 10.0.0.11
    Internal Port : 9887
    and i can see the External Ip Adress of the User.
    Yes i know there some ports missing but it was only an Test.
    Sargnagel.
    ----------------------merged----------------------
    HI Anruso101 can you Please take an look to your Router an check how you do the Portforwarding ?
    So please try an Portforwarding at your Router like this. ( Save your Current Config !!! )
    Port : 9887 ( If you have running an STandart Install )
    Protocoll : UDP
    Target IP: 192.168.0.10 ( Your TS3 Internal IP Adress )
    Port : 9887
    and Test it Please.
    Regards Sargnagel
    Ohhh bye the Way open the Filetransferport too. 30033 (TCP)
    So your USers will get the Icons.
    I Hope i could Help an little Bit.
    Regards Sargnagel.
    May 2014
    Clients getting same IP address as the server!
    Hi, i have a Teamspeak 3 server hosted at my own, but i noticed that all clients that connect to the server is getting the same ip address as the server, do you thing this is a teamspeak 3 issue? or router maybe? what do you thing?
    i cannot ban ppl if they have the same ip.
    December 2004
    RF
    3,008
    Fix your router configuration.
    May 2014
    ok, i tested without the router and it works fine (clients gets their real ip) the problems might be the router, now i have to find the problem. If any of you can help me ill be so happy haha .....
    my router: tp-link ac 750
    December 2004
    RF
    3,008
    They have their own support line, you know?
    4,368
    I have the feeling that there are more routers models than people on the earth. So the chance that anyone has your router is nearly 0 and the chance that anyone on the forum has it is equal to 0.
    May 2014
    Did you solve this issue? i have the same problem, tell me your solution please!
  1. Server drops users if more then 12 clients connected
    By tbede in forum Server Support
    Last Post: February 6th, 2014, 08:04 PM
  2. Replies: 1
    Last Post: September 4th, 2012, 02:28 PM
  3. Skinning all clients connected to a server
    By rebeldragon611 in forum Skins / Icon & Sound Packs
    Last Post: April 9th, 2012, 08:05 AM
