Results 1 to 5 of 5
    May 2014
    9
    Channel Sort Permission Help
    Hello everyone. I have searched up a few topics regarding permissions and channel sort, but wasn't able to find what I was looking for. Very similar to this topic, I want all guest created channels to automatically be created under a certain channel without giving them the option to sort or modify. Is this possible? Below is a screenshot of my server.
    I want the guest created channels to automatically be created under the "Temporary Channels." Thank you in advance.
    EDIT: I moved that channel shown in the image to the Temporary Channels manually.
    June 2013
    TeamSpeak Community Forums
    108
    Reply
    Yes there is a way and its pretty simple. All you have to do is revoke the rights to create channels from the guest server group and grant them on the channel instead, but also make sure that i_channel_min_depth is 1 so they have to create a sub channel and also that b_channel_create_child is enabled. This will force them to make a sub channel under temporary channels. Then you can also write a helpful message in the description in the temporary channels section header
    May 2014
    9
    Hello itteam. I'm sorry, but can you post images or guide me on how to do this? I am new with the permissions stuff. Thanks!
    Also, do you have any suggestions on what I should rename the Temporary Channels to (if I should)? I know people these days only read what's shown and don't really like reading into things, so I want to make it clear to them that channels should be created there. I don't want to name it something like "GUEST-CREATED CHANNELS GO HERE!" or something though... I hope you understand where I'm trying to get at.
    June 2013
    108
    First of all, make sure that the guest group has the channel create permissions like this... Click image for larger version.
ID:	10528. When you have done that, set them on the temp channels channel like this Click image for larger version.
    May 2014
    9
    Thank you very much, itteam! I have configured everything to the images you have provided and tested. It is working the way I wanted now. I just hope this will not force guests to find a new server and that they actually read. Regardless, thank you!
  1. Cannot Change Sort Id permission
    By TapouTony in forum Permission System
    Last Post: June 29th, 2015, 01:57 PM
  2. Channel Sort Order permission and Hosting
    By Jankec in forum Permission System
    Last Post: March 1st, 2013, 09:25 AM
  3. [Resolved] I don't have permission to Modify Channel Sort order
    By Crabman111 in forum Permission System
    Last Post: August 22nd, 2012, 01:49 PM
  4. [Resolved] How to disable Sort Channel permission for Channel Admin
    By SoKoOLz in forum Permission System
    Last Post: February 23rd, 2012, 04:07 AM
  5. Bug - sort of in permission system
    By markgm5 in forum Bug Reports [EN/DE]
    Last Post: January 29th, 2010, 03:21 PM
