Results 1 to 2 of 2
    May 2007
    Eastern NC
    1,794
    Antifreeze LUA Module
    I was not planning on making a thread for the plugin since it is only of use for a limited time, but the thread I was posting update notices in was closed so I've now made this thread.
    Current version (1.12) can be downloaded from here.
    This is a simple LUA module so it should work on any system even though Windows is the only current system that I've seen freezing from the malformed messages. While not needed in clients older than 3.0.14 for freeze protection it can still be used to keep the malformed chats from getting logged in the chat log and then causing issues when you update to 3.0.14 or later. Sadly, this module does not clean chat logs already containing malformed messages. Think of this module as a vaccine to prevent freeze, not a cure. The cure would be cleaning or wiping the chat logs.
    Install is made simple via the TS3 one click install package. After running it, make sure the LUA plugin in TS3 is enabled and the Antifreeze module is enabled.
    Currently there is no internal notice about updated version of the module; I suggest subscribing this thread if you want to get notified about updates.
    May 2007
    Eastern NC
    1,794
    1.12 release to address the 3.0.15 bbcode freeze exploits from worthless people that think that is their job.
    Last edited by Screech; July 11th, 2014 at 07:28 PM. Reason: I was asked to not feed the trolls.
