Results 1 to 7 of 7
    June 2014
    Client info panel is buggy on rename
    I am fairly new to creating/modifying skins, but I noticed that when I updated a skin name and renamed the links that my client information panel got messed up.
    I downloaded one guy's skin, and made changes of it so the work was mine, but I used his base so I could use his qss style sheets, as I have no idea to go about that (Even after reading that documentation.)
    Any help would be appreciated.
    Please see the below pictures:
    Before: http://i904.photobucket.com/albums/a...ps684a993a.png
    After: http://i904.photobucket.com/albums/a...psb7735e85.png
    If you need me to submit my code, or rather a portion of it, let me know.
    February 2011
    18
    If I'm right you want back to how it looked like before? If answer is "Yes" then just in folder with your skin name remove or change file named "clientinfo.tpl"
    *Notice*
    Every .tpl file response for how the right side of teamspeak looks like. If they do not exist it uses default ones making it looking like ur "before screen".
    Netherlands
    153
    Do what WavezZ says. There should be a folder called WoW - Cataclysm. Rename that folder to the exact name your stylesheet has. Make sure you update all the links in your own stylesheet with the folder title as well. Also I gotta say that the WoW skin is probably the worst one there is to work of.
    June 2014
    Thanks! That helped with the theme - but maybe I'm missing something else, it doesn't change the text as it was before - Maybe I need to change another file. When I changed that it only changed the background on it.
    February 2011
    18
    What text? What exactly is not changing? I think you have problem with .css file then.
    June 2014
    The text inside the Client information Panel. The Text is changing which is the problem. I looked through my CSS but I don't know why it changed, when I only renamed the file name / Directory.
    You see in the first picture, the text is pretty small, but fits nicely, and doesn't go down in a column, but in the after, the text gets greatly increased (I checked my CSS and the font size is set to 6). Any suggestions on where else to look?
    (Also, I greatly appreciate your help!)
    February 2011
    18
    Would you mind to contact me via my TS3 server? I will send you informations on PM. Hope I will help you out directly.
  1. [No Bug] Query Client + Connection Info = invalid client type
    By Linnun in forum Bug Reports [EN/DE]
    Last Post: January 19th, 2015, 08:38 AM
  2. Info panel showing images
    By Efficiency in forum Client Plugins / Lua Scripts
    Last Post: June 29th, 2013, 05:10 AM
  3. Client not visible in panel
    By g8wayrebel in forum General Questions
    Last Post: August 30th, 2011, 10:54 PM
  4. Client SDK buggy or is it me? onTalkStatusChangeEvent..
    By skyflash_de in forum Client Plugins / Lua Scripts
    Last Post: June 23rd, 2011, 10:12 AM
  5. Info Panel Nickname
    By Izamina in forum Client Support
    Last Post: September 27th, 2010, 09:09 AM
